What apexi power fc??
Started by Jot17, August 07, 2012, 02:07:53 PM
Jot17
Hey guys,
I want to ask what apexi power fc do I need what model number?
My chassis number starts of fd3s 4. Is that a 1992-1995? Because my car is registered as 1996 so I\'m confused lol please let me know if you guys know what power fc I need.
Thanks!!
Speedline Imports
The Apexi model numbering scheme can be a bit confusing as they dont match your cars chassis number.
If your car chassis number starts FD3S-4xxxxx then your car is a 1996 model which requires the Apexi PFC starting with the serial number FD3S5
If you have trouble finding one, I have a 1996 FD leaving Japan soon which is for breaking which has one.  Probably available in about 8 weeks time.
martin@speedlineimports.co.uk
TEL. 07742 690672
Monday-Friday 9am-5pm
Speedline on Facebook
Jot17
Quote from: Speedline Imports;831944The Apexi model numbering scheme can be a bit confusing as they dont match your cars chassis number.
Ok, the reason why I asked is because I read up on here somewhere that fd3s-4 is 1992-95 so maybe that was wrong, but that\'s great thanks for the info, and as for the power fc, if I don\'t have one by then, then I will get in contact on your number if that\'s ok.
Thank You!
Jot
monkey-fd3s
Hi Jot
Sorry I\'m still away the moment so haven\'t had a chance to look at popping round to see you, but I haven\'t forgotten.
Martin\'s right - the thing that is confusing it that the chassis number is FD3S-4 but the ECU will be part number FD3S5.
The ECU I had was FD3S4 which was for a 92-95 8-Bit ECU, which has different connectors.
Martin, the car thats coming from Japan - is it possible to take a look at the parts once it arrives - it will be the little bits and pieces I need....
Dave
Speedline Imports
Hi Dave,
Let me know what you need as I have another shell which still has a lot of the small stuff on ;)
TEL. 07742 690672
Jot17
Quote from: monkey-fd3s;831976Hi Jot
Dave
Hi,
I did reply on your parts for sale thread but you didn\'t reply so I thought you was busy, I want to ask another question, what is the difference between 8bit and 16bit, which one would I need?
Thanks.
yehreally
Understand you can use an 8bit \'FD3S\' or 16bit \'FD3S5\' on your 1996 car (these units are for 1995-1998 models).
Although, Mazda\'s term "16-bit" can be vague. It\'s possible the chip itself didn\'t change at all. They may have had a slower 16-bit-instruction-capable hybrid chip running 8-bit math routines for faster execution time. Maybe for the newer configuration, they may have simply bumped the clockspeed up and changed the instructions and data-tables (ram/rom size) to work with 16-bit routines. Some of the 8bit ecu\'s had a three plug configuration and the newer units had four plugs. Either way there are harnesses out there for these. Drop me an email if you are still looking for one of these.
Quote from: Jot17;831983Hi,
Thanks.
