cold start issue with a pop
Started by nadz, December 06, 2012, 11:01:22 AM
nadz
I have had an issue since yesterday now early morning start I start the via remote start and the car take strugles to start it pops and then re starts and it starts is this due to it being really cold or an issue? But otherwise on hot it starts fine and after 6hours it starts fine. Just the early morning start. Any ideas.
So are you says that if you start it normally with the key it\'s OK?
nadz
Quote from: clive;843742So are you says that if you start it normally with the key it\'s OK?
i havent started the car in the morning with the key for a while. i guess i will try this tomorrow morning and see how it starts. but otherwise through out the day using the on start up its fine.
JayDee
Probably the cold start settings in the map, if on pfc now the weather is cold.
shaunwil
Could be a weak battery too, cold weather does kill them a lot ! May just be taking more to turn over and dumping fuel into the exhaust !
Shaun
nadz
Quote from: JayDee;843746Probably the cold start settings in the map, if on pfc now the weather is cold.
confused! i will need you to map the car for me at some point soon so will be in touch with you for that. as it is running abit rich with alot of fume smell carl had mapped the car initially.
nadz
Quote from: shaunwil;843751Could be a weak battery too, cold weather does kill them a lot ! May just be taking more to turn over and dumping fuel into the exhaust !
Shaun
battery is fine. but will try starting the car tomorrow morning with the key and see if that makes any changes.
JayDee
Cool give me a call when your ready, you have correction factors for different temperatures, see how it is with the key.
Quote from: nadz;843755confused! i will need you to map the car for me at some point soon so will be in touch with you for that. as it is running abit rich with alot of fume smell carl had mapped the car initially.
nadz
started the car today with the key started fine. i think its due to the cold weather as i had to press the accelerator slightly for it to start straight away. without it strugling.
