advice on emissions failure
Started by duff, October 05, 2004, 05:44:57 PM
duff
hi every1
i had my rex MOT\'d today and it failed on the emissions as you can probably tell. i have a blitz cat back exhaust with no pre cat i was wondering if any1 else has had this problem? and if they did how did they get around it or does something need changing on my PFC
cheers ant
jetpilot
You should be able to alter the fuelling on the Power FC to lean out the mixture to pass emmisions, i dont know how, but the boys in the know will able to tell you.
Try the specialists.
duff
cheers pal i thought i would put a post on just 2 see if any1 has had this problem before thats all im gonna contact WGT tomorrow and see what they say
duff
has no 1 else had this problem?? on the MOT refusal form it said that there was a problem with the lambeda sensor but i dont no if this would affect the results.
i spoke to WGT and they said it should still pass because it has got the center cat also that fd\'s have different figures for emmsions. but just wanted to no if anyone else had any views that they might have??
cheers ant
gsb876
