will rx8 caliper fit an fd
Started by imiitek, June 16, 2013, 06:26:51 PM
imiitek
just want to no if the mounting holes line up and offset of caliper the same ?
Sorry no, same style of calliper but designed to fit a much bigger disc also has a different pad shape meaning you would need to fit the carrier as well.
May be worth investigating adapting the whole calliper and disc assembly as it would give the FD a big rear brake set up.
imiitek
cool thanks m8 was gona buy a brake kit but its not worth the hassle
thanks
