Its making LOADS of noise
Started by J4P RX, July 16, 2004, 07:05:48 PM
J4P RX
Just driven it (ok only 2 miles) with the new suspension on, and theres loads of knocking noises.  Its seriously load and very constant.  It doesnt feel like anything is happening at the time though.
Should this concern me?  Bear in mind im drifting at Silverstone tomorrow too...
scooby_si
is it only when going over bumps etc or whenever wheels etc are moving?
Did you get adjustables in the end & if so what setting you got them on ATM?
Si (stills knows fek all but fort http://www.smileycentral.com/?partner=ZSzeb008\' target=\'_blank\'>http://smileys.smileycentral.com/cat/26/26_28_4.gif\' border=0> he\'d ask....)
jetpilot
Hi Lee
Is it working per say, i mean, does it feel like its damping right etc.
It would be very wierd for suspension to make noises like you are suggesting.
scooby_si
& you mean it dont feel like the suspensions bouncing at all or that knocking isn\'t doing anything?
Si
J4P RX
It feels ok, no-where near pushing it though as the noise concerned me.
I spoke to the guy who fitted it and he doesnt know what it could be as he assures me everything is done up properly.
MikeLMR
not sure what the FC suspension looks like (semi struts up front and rear ?)
What have you had done ? new struts, springs, bushes ? everything ?
I would go round what you can see and spanner check everything to ensure its tight. The usual suspects are the nuts that holds the shock absorber rod into the strut top. (causes the shock absorber rod to bounce around under normal vibration)
As I saif i\'m not too sure what the FC looks like suspension wise so I could be way off ... to be sure its not somthing it should be doing if fitted correctly.
jetpilot
Its not those worn bushes is it Lee?
J4P RX
QuoteOriginally posted by jetpilot
No idea, not technical at all!
Did the kit contain solid top mounts? If it does then that will be it!
The standard suspension uses rubber top mounts to kill this noise.
jetpilot
Lee, i also am no expert. Just know they were worn but cant see how it would make them knock unless they were bottoming out so to speak.
I would try for a second opion from a garage, just in case.
jetpilot
Ok, Lee, it looks like Fish has jumped to the rescue. It does contain pillow mounts.
J4P RX
To be honest im a little lost on this now.
Is it ok guys?
If you have solid top mounts then the rattle is normal.
