Nur spec R question?
Started by Fats, August 16, 2012, 12:48:01 PM
Fats
Just purchased a nur spec but was wondering if anyone could clear this up for me, the system is 3 inch but then drops to about 2.75 inch at the flange???? this normal for a nur spec R
wolfie1
its to meet up with the standard exhaust
Fats
So this is normal then?? Im debating cutting off the flange and welding a 3 inch on
fil_auto
Quote from: Fats;833095So this is normal then?? Im debating cutting off the flange and welding a 3 inch on
I wise idea, as I\'ve been advised to do with my Apexi Titanium system ( that does the same, tapers down to 2.75" .... especially if you\'ve a 3" decat / silenced midpipe :mmmm
neil_jdmr
Funny my nurspec R doesn\'t taper down at all it\'s exactly the same diameter as my 3" straight pipe I got this system as a whole package and it\'s all 3". I\'ve had it off many times but now you have me wanting to check again but I\'m 99% there is no tapered part
wolfie1
his is maybe the "s" version
philiwily
Mine doesn\'t taper, Apexi is the only one I\'ve seen that does this.
Fats
Don\'t think it\'s the s version because there\'s no jasma approved plate on the exhaust, bit of a ball ache! My system is 3 inch from the turbo back, any one think this would cause much of a restriction or am I being to fussy?
