fuel question
Started by gmogle, August 17, 2012, 06:00:26 PM
gmogle
Guys,
Silly question but is there any way of releasing the fuel pressure if you dont have a battery connected ?
I wasnt planning on upgrading my fuel when I took it to bits but halfway through I thought it would be a good idea to do but haven\'t released the pressure at all.
Any thoughts please ? Or should I try and get it back together with the current fueling and get it started then try the pressure reliever method ?
Cheers,
Gareth
The fuel will drain back into the tank naturally, you just need to give it a few minutes
gmogle
Thanks M1tch, will tread carefully when taking the fuel lines off.
Will I need to plug the lines at all ?
