Problem: Pop up lights "popping up".
Started by Kodiak, July 05, 2012, 08:08:27 AM
Kodiak
Whilst out yesterday I found that during hard left hand cornering the lights were popping up. Almost as if a wire somewhere were swaying and causing a connection with something it shouldn\'t. Straighten back out and the lights stay down...
Which wires would need checking? :3Confused
Cheers chaps.
FC3S T2 in Red(-ish)
2yr old daughter sits in car, says "It\'s too loud daddy"  :flamed
It will most likely be in that big bundle of wires passing in front of the radiator...
Kodiak
Cheers Prof. (Always to the rescue! :Thumbsup!)
I was rather hoping it would be them rather than something with the controls.
Cheers.
Will report back this evening :)
Kodiak
Nope. Connections seem ok in there.
Could be a dodgy relay - one of the relays in the front near the radiator is resposible for popping up the headlights - I have a feeling from memory it may be the left most one - but I can confirm tonight when I get home and look at the wiring booklet.
Just try reseating all of them
Kodiak
Problems fixed itself.
Maybe something had worked loose and by checking I\'ve re-connected it properly.
Happy days.
Loving my FC :mmmm
