God of the Pod Competition at Rotorstock
Started by Lisa, August 10, 2012, 06:27:02 PM
Lisa
God of the Pod Competition:
So you think you’ve got what it takes to become THE God of The Pod? Well you and your wheels are going to need to be quick in a straight line and around corners.
The top 30 RWYB times of the day will score points based on their position, 1st claiming 30 points, 2nd claiming 29 points and so on right through to 30th picking up 1 point.
These points will then be combined with the points from the Handling Track, allocated using the same system to find the overall God of the Pod.
 We’ll do all the number crunching; all you need to do is come along, sign up to run on both tracks and give it a go!
The same car must be used for Strip and Handling but tires can be changed.
Trophies will be awarded for the fastest ¼ mile time of the day, God of the Pod 1st, 2nd and 3rd and also for the fastest time recorded around the Sprint Track.
Trophy presentations take place after racing on the startline.
REgards
