ASAP reply needed
Started by nc30pete, June 28, 2012, 08:35:55 PM
Mikey22
How do you reset the apexi to factory base map?
nc30pete
Think in the etc setting on the commander you can choose initialise function and that goes to the base map.
Mikey22
Ah right i might give that a go when i get back. Im not running a remap or anything so i wont loose out. Not that it would would anyways as im not really supposed to have the apexi on an automatic :(
bobster
The Oil injectors are only fed with atmospheric that is filtered in the rats nest somewhere. If your premixing and have ditched the OMP then thats not it.
It sounds flooded... possibly because your plugs or stop start or whatever.
Have you checked that the map sensor is plumbed in properly?
Try tow starting it... thats how I\'ve started a few stubborn engines
arrouk
Might sound daft but check you map sensor feed first.
Then you can check for a spark at each plug but keep your plugs in and use a spare or disable the injectors ;)
Hth
Matt
shaunwil
Quote from: bobster;827770The Oil injectors are only fed with atmospheric that is filtered in the rats nest somewhere. If your premixing and have ditched the OMP then thats not it.
Balls, your right. I plumbed the pipe into the front of the air filter as shown in the manual.
Shaun
nc30pete
What feed voltage are you supposed to have at the map sensor plug? Which of the three wires do u check from? Trying to look at fsm but I\'m not finding what I want on it. Think it\'s pressure sensor but I\'m not finding which wires to check feed from. I did a feed check to my map sensor and I get 4v from two of the wires and 5v from another combination ...
Unless I have some std comparative data to test against my readings may as well be in Chinese lol
Must get round to printing the fan and other manuals because reading it off my lappy is a royal p.i.a !
