Dash lights don\'t work
Started by allrounda88, June 07, 2012, 03:13:03 PM
allrounda88
Hi
Yesterday i drove my car and everything
Worked fine
Today I have switched on the headlights and no
Light on the cluster
So is there an extra fuse for it or
What could it be
allrounda88
just to add
other lights work fine
heat lights,brake light etc. lighten up fine
radio work and interior lights also work fine
only the cluster of the the speedometer,rpm meter etc. lighten up
wolfie1
you havent moved the dimmer switch to dim?
allrounda88
Nope
Rear lights didn\'t work to
But found the fault
It was te fuse
