Anyone try nitrous on fd .
Started by mowales81, May 02, 2012, 06:46:31 PM
mowales81
Hey guys just wondering is good idea to but nos on fd to add 50 ps a shot or is to risky I mean will damage my engine or not also witch one is the best for rotary wet kit or dry one ?
Mo.
Banned for fraudulent activity.
Quote from: mowales81;821920Hey guys just wondering is good idea to but nos on fd to add 50 ps a shot or is to risky I mean will damage my engine or not also witch one is the best for rotary wet kit or dry one ?
Mo.
Nitrous and rotaries don\'t really go, it would have to be a wet kit with a massive amount of extra fueling to avoid the engine going lean on boost, its better just to get a slightly larger turbo if its only 50bhp more you are wanting.
B.Martin
Vin diesel tried it, worked great for him :Giggle
Quote from: B.Martin;821959Vin diesel tried it, worked great for him :Giggle
Thats the nasty US stuff, UK nitrous just gives a more progessive increase in power through the rev range :)
Its fine on drag cars though
oyvindjs
the cash you have to spend on a wet kit, is cash you rather put into reliabilitymods, so you can up the boost alittle, and achieve a more reliable engine, AND enjoy those extra 50 bhp every time you want it, without having to go tap it up all the time. win win!:p
dthebuk
more boost means less engine life.
How about running nitrous to supply power whilst spooling up a ridiculously large turbo? Should get reduce whatever problems nitrous causes as you\'ll be using it at lower power/engine speed
:burnout
2 step or properly sized engine ports for the turbo you want to spool :) engine life starts to degrade at around 1.4bar, on a massive turbo you have other stuff to worry about at that power :rollin
Grant Monkhouse
Mo.
If your after just 50 HP then I would suggest an increase in boost along with a few supporting mods, it would be Beter money spent in the long run.
Nitrous doesn\'t really work on turbod rotaries unless you are using it to spool a huge turbo.
A none turbod engine would suit the nitrous setup, a wet kit too so that the system supplies the extra fuel rather than having the engine ecu having to deliver the extra fuel needed. A 50:censored::censored::censored::censored: would be a but pointless IMO, 150:censored::censored::censored::censored: would be worth having.
There is a thread on ausrotary where a guy is installing a 13B PP with nitrous into his road going rx3. Should be good to see the results
mowales81
Ok I understand now but how I know the max power for my turbo all I know it\'s s300 Borg warner and that\'s it so if I want to increase the boost with bigger injectors I still don\'t know if I can gain extra 50ps of that turbo any idea what is the capacity power for the type turbo please?or how do I found out ?
Mo
Grant Monkhouse
Quote from: mowales81;822059Ok I understand now but how I know the max power for my turbo all I know it\'s s300 Borg warner and that\'s it so if I want to increase the boost with bigger injectors I still don\'t know if I can gain extra 50ps of that turbo any idea what is the capacity power for the type turbo please?or how do I found out ?
Mo
Have replied on your other thread bud ;)
dthebuk
Quote from: m1tch;8219952 step or properly sized engine ports for the turbo you want to spool :) engine life starts to degrade at around 1.4bar, on a massive turbo you have other stuff to worry about at that power :rollin
so theres lots of 500 bhp engines doing 70k miles?
:burnout
