Robertio in dead engine shocker :-(
Started by Robertio, July 03, 2004, 07:39:35 PM
Carl
I don\'t think it is a good idea to be cranking the engine over anymore  which may create more unnecessary damage.
A thorough check by Robbie appears to have already confirmed that at least 2 apex seals have either got damaged or are carbon locked.
The most likely being damaged in my opinion,but either way the engine needs to come apart and be sorted.
I would like to see what has happened to it to confirm at least a starting point in order to try to work backwards to determine the cause.
Can you at least get the engine down to me Robbie?I will pull her apart and see what has gone wrong so that we all know rather than keep guessing.
Kind regards
Carl;)
