Diff mounts or engine mounts
Started by C18WWN, March 15, 2012, 08:21:34 PM
C18WWN
What\'s more likely to cause juddering at low revs.
I need to iron out a few rattles a noises, and this one
Pushes my buttons everytime it happens.
Think I\'ll be buying a diff brace too in the near future
shaunwil
Engine mounts are much easier to replace. Swap out with 2 hockey pucks each side and a 2nd steel mounting bracket for a cheap poly upgrade too.
Are you running a stock clutch ? What quality of tyres are on the rear of the car ?
Shaun
C18WWN
Stock clutch as far as I\'m aware, rear tyres are nearly new falkens...
Will look into the puck mounts tho, thanks
