greddy emanage
Started by billybobbooth, February 13, 2012, 10:58:23 AM
billybobbooth
am i right in thinking that the emanage without the optonal injector harness can control the stock injectors??
mate said i can have his came off a mr2 but the unit is universal all i need is the rx7 mapping cd unless the tuner already has it and the rx7 wire harness hence why im thinking of having it.
but i know the injector harness for the emanage can only add 2 extra injectors. where the ultimate can do 4-8 extra injectors. but when the unit is free im not going to complain.
anyways back to the point can this handle mapping bigger injectors in the stock place via the stock ecu or will it be easyer to just get the ultimate want to use e0-1 i have and this is designed to work with both.
billybobbooth
forgot to say my other option is a aem standaloan ecu
e0-1 won\'t talk to the ultimate, but the ultimate will give you much better control than the older emanage - you can adjust fuelling without affecting any timing for instance - not possible on the blue.
Still - free is a good price ;)
Without the injector harness, the blue can only alter the airflow map which affects fueling (but also timing).
billybobbooth
prob wont get the emanage then as the injector harness can only do 2 additional injectors unless i just put one in the greddy intake pipe just before the tbs as if my timing is spot on i dont really wanna try and up the fuel just for it to mess up the timing, although it will be on a hybrid turbo so may be ok. but think ill just stick with looking for a ultimate
thanks prof
