Single Turbo Help!!!!
Started by Adam, July 03, 2004, 05:56:27 PM
Adam
Hi all...
Just need some help on installing my HKS T04 single  turbo...
I have the instructions but they are in japanese :(
The only problem i have is with the vacuum system.  The instructions are not very clear.  I always understood that most of the hoses are removed but i still seem to have a lot left.  Also i have a vacuum chamber on the top plus the one mounted on the front....doe these need to be ditched or reused?
Also which pipe is connect to the waste gate?
Any help, pictures or advice would be great
Adam
gsb876
Hi Adam,
i believe chap called Wav on here is in Notts and might be able to help you out, hopefully he\'ll see this here thread and help out???
Real name Paul.
Adam
Thanks for that but i know paul.....  not sure he is too clued up on the single turbo set up though....  but i may be wrong...
Adam
gsb876
Ok Forest !!! i mean Adam,
next possible thing to do is ring an expert closest to us will be Pip at wgt engineering : 01606 48866 - Northwich other side of stoke.
Gurj
Adam
Tried that one sheep shagger.....i mean Gruj... :)
Needed to know for tomorrow really as i hope to firing it up since the rebuild....  So if any one else can help it would be much appreciated.
Adam
gsb876
SUPER RAMS!!!!
Adam,
midlands meet 18th july in Derby please try to come down if you can mate, just off the A50 at the stenson bubble inn.
Check the meetings page.
Adam
Rx7 won\'t be ready mate....  not for a long time yet...  it\'s in bits on the garage floor  :(
And i don\'t fancy turning up in a fiesta...lol
scooby_si
ah cummon dont be shy i been mondeoing it for ages & if Gurj aint shy of turning up with his ugly mug then any1 can do it....lol although saying that i was trying to get the scooby meets on for 18th didnt realise there was a bubble inn on the same day booger was hoping to meet http://www.smileycentral.com/?partner=ZSzeb008\' target=\'_blank\'>http://smileys.smileycentral.com/cat/15/15_10_5.gif\' border=0> ya at sum point Adam...
Si
