rx8 20v turbo motor swap
Started by tinker-27, January 09, 2012, 09:19:41 PM
Grant Monkhouse
You can use WI on NA motors too, but the benefits are not the same. Increased mpg and decarbonised engine internals. But with turbos the benefits are huge and even more so when ore turbo WI.
Will66
I think it is a bit too keen on N/A but if and when I go for an F/I Rotary, it will be W/I and probably on stock ports.
"Eat it with a chopstick!"
