so how does..
Started by Andyp, June 29, 2004, 05:48:44 PM
Andyp
so how does one got those bloody annoying ECU screws out holding ones stock ecu in? I can\'t get a screw driver in there! Tried with a lil magnectic socket head that holds screw heads in too and still no joy?
Wanna try the Power FC out but bum me if I can get the top ones out let alone the bottom ones :-0
thanks in advance
Buy my car foo! :D
iaint
Mine was just held in by a bracket which needed a 10mm socket to undo, no screws at all.
It\'s the whole metal box that comes out...
Iain
J4P RX
Yeah getting it off was easy, getting the wires out the back was a nightmare!
there are several techniques -
- pull it really really really hard.
- hit it with a hammer
- using a jigsaw and drill, go in through the wing and remove from the exterior of the car
- remove the car from around the ecu
- seal the ecu in shrink wrap, pour in petrol and ignite
- are you trying to use a flat head in a cross head?
- remove the engine, cut a hole in the firewall big enough to fit both hands in and use a friend on the inside directing you to undo the screws
-rotate the bracket around the screw
and finally
- use a small child with an incredibly strong grip to stand in the footwell, and lever themselves against the sides of the footwell and offer huge amounts of torque to loosen the screws
I hoped this helped
gsb876
Erm........... i dont think its the Sun that shines out your bum!!!!:rollin :rollin :rollin
evildave
QuoteOriginally posted by J4P RX
yep, damn japs and their short looms and tight plugs
Andyp
:rollin @ bish
you\'re a treat trecale :D
so the whole dam bracket comes out eh? that kinda worries me as somethings being earth\'d on mine... i\'ll post a pic tm :)
Buy my car foo! :D
Andyp
Right, just took some photos...
What do we think this black cable is doing thats bolted into the bracket then? Is it ok for this to come off. Seems to lead to the ECU..oddly enough
Here\'s a side view too, can\'t see that it extracts power, just looks earth\'d to me?
So can I remove this do we think and where (can someone draw) do you upstrap this bracket?
much thanks!
Buy my car foo! :D
Andyp
or is it just that nut and it comes out?
Buy my car foo! :D
Ric
Black lead is an earth probably.
ric (rexy has gone now all I have left is NFSU2 :( )
black lead IS an earth, and you should be able to find a new home for it happily enough.  Come on y\'big girls blouse - GET IT OUT AND SHOW IT WHOSE BOSS.  Finish removing your ecu shortly after.
Andyp
hehe ooh put ya tounge back in ;)
I asked on the US forum, some guy said it was just a grounding wire for the ECU. I shall lob the newen in at the weekend when I clean my car and tattoo it with a ring sticker or two, to make myself look ard :rollin
Buy my car foo! :D
Ric
QuoteOriginally posted by Andyp
make sure you earth the new one otherwise it might do all sorts of funny things with all the electrical interference in a car.
Andyp
Buy my car foo! :D
