heater problems
Started by rising son, November 27, 2011, 08:55:01 PM
rising son
right, the heaters in the car dont work/blow, all the buttons on the controlls heat up, aircon etc, and after 20 around minutes of driving the window does totally clear, but no blowers at all... any ideas?
rx-dave
Sounds like either a fuse or your blower motor, if you need a motor i\'ve got a good one there for £15 if you need it but hopefully it\'s a fuse :Thumbs-up
Dave.
rising son
excellent dave.. any idea where the fuse sits for this ? if the fuse is fine ill buy that from you !
rising son
think ive found the fuse... big black 1? looks ok i think..
rising son
well problem is fixed i think... bought the car ith that fault... took the fuse out (when i pulled it out i noticed it was one of the old buttom style fuses with the button on top) took it apart then built it up again with the buttun pushed in and i have working heaters.... shocked actually, cheers for the tips anyway
