lowering springs quick answer needed
Started by rising son, November 23, 2011, 05:13:48 PM
rising son
if a company is advertising lowering springs and they are listed for an rx7 mk2 85-92, will they fit a turbo II vert ? is there any differences in springs from turbo/NA, vert/coupe ???? cheers in advance
L18M
all teh same but cab springs r bit stiffer i believe due to cab being bit heavier.
better to get proper set of uprated and lowered springs dampers or coilvoers if you can stretch your budget.
also advantage of coilovers on fronts is can fit more variety of wheels and offset of the front.
cant remember exactly what offset but some aftermaket wheels foul on the front springs.
festa
Hi Mate, the verts and coupes have different rate springs as verts are a bit heaver I don\'t think its that much of differance .
festa
rising son
ive got ohlins adjustable shocks on standard springs, just needs more low, can adjust damper with the shocks anyway, as for wheels im just waiting on longer studs and spacers then my 8j 10j rotas are goin on :)... appreciate the quick reply... away to buy em
