injectors on ebay?
Started by leeroy_25, November 15, 2011, 08:45:53 PM
leeroy_25
Just a long shot and I suspect I know the answer but wondered if anyone had used these injectors in their FD and had anything to report good or bad?
http://www.ebay.co.uk/itm/NEW-1600cc-FUEL-INJECTORS-TURBO-TUNING-150lb-RX7-/160642320619?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item25670748eb#ht_4144wt_952
Let me know.. normally pay peanuts get.. well you know!
But not always the case!
AtomicRex
Cant really comment on what they are like, but if in doubt I can put them on our injector machine and if necessary service them.
leeroy_25
I just found out they are made in Hong Kong if that should make any difference? What do you charge to flow test and service them? I presume that still does not garauntee something going wrong with them? but then nothing is garaunteed! What would you run if you were getting 1600cc injectors? What can you offer? Am I correct in thinking you can also supply the pigtails for the RC Engineering injectors? What do you make of those?
I assume the pgitails can be cut from any car with a suitable wiring plug?
Basically I am sizing up for my 20B to make 600-700bhp flywheel. Am getting some 1000cc injectors off Mir on here with the intention of just running stock primaries with those.. but I think that will leave me short of fuel and I am not sure putting 850cc Primaries will be the answer and maybe I just need bigger secondaries to start with?
Thank you
Lee
AtomicRex
Hi Lee
If you want injectors I can supply big injectors and they will be high impedence ones.
Flow testing, cleaning and servicing the injectors is £10 each.  I can supply a new set of injectors that will suit your application for about £80 each.
If you skimp on injectors and your engine blows up, then you\'ll have a rather large bill!  I can do high impedence top feed primary injectors also.
Drop me over an email and I can chat further with you.
leeroy_25
Hi there, I clicked the mail me link at the bottom and sent you mail from my hotmail yesterday.. leeroy_25.. Hopefully you picked it up?
Lee
