Interesting noise from the engine
Started by yiug412, December 10, 2011, 05:12:45 PM
yiug412
Hello!
I was taking the car apart this afternoon, im breaking the car due to engine failure. I got my UIM off  and turned the engine with a breaker bar on the big crank nut. it sounds like the inside of the chamber is full of water while i was turning it. would that be the water seal gone rather than the tip?
Louis
1984 Honda Civic EF single carb 1.4
1989 Nissan Cefiro A31 RB20DE
1990 Toyota MR2 Turbo SW20 3SGTE
1990 Mazda RX7 TII FC3S 13BT
2004 Mazda RX8 231 SE3P RENESIS!
1974 Leyland Mini Mk3 1000
1994 Mazda MX5 1.8i BP
2003 Mazda RX8 231... something with turbo.
Always put a smile on you when the \'beep\' goes on :chat
Could just be the sound of the compression, did anything come out the exhaust port, soft seal rebuild isn\'t much
Ricco_04
Take both lower spark plugs out - if its got water in then you will see it being pushed out when you turn the engine.
