FD RX7 running problems
Started by Dan Dillinger, November 04, 2011, 04:36:24 PM
Dan Dillinger
Recently bought a FD RX7, bought it in a "non running" state.
However, after putting some fresh fuel in and charging the battery, managed to get it going!
It\'s running rough as hell! Doesn\'t want to idle, miss-firing etc etc.. if I take my foot off the accelerator it just dies!
When I put the ignition on, the rev counter reads all over the place
When the engine cuts out, the TPS sensor makes a buzzing sound! I unplug it and it does go away.
Other things to note, i\'ve renewed the plugs. The car also has an apexi power FC ECU
Any help please? Total new to this.. where do I start?
compression test was next on my to do list
TRIND-FD
New plugs,  if it a twin turbo, try resetting the pfc as you will prob want it mapped anyway. Let it learn the idle, but could be vac pipe split, check map sensor and pipe. Comp test
V8 fd\'s rock :cool
philiwily
I could probably have quick look at it over the weekend if you like.
Phil
Dan Dillinger
Phil, that would be amazing if you could??
The car is in West Lothian, just off junction 3 on the M8 (deer park roundabout)
i\'ll pm you my number!
Dan
Dan Dillinger
Hi Phil, i\'ve sent you a message to your hotmail account!
Dan
