TMIC pipe
Started by B.Martin, October 28, 2011, 04:13:42 PM
B.Martin
Any one got a spare one laying around that they can post up exact measurements for, I really want a purple one for when I fit the ARC and will no doubt need a custom one. Could do with the pipe width the diameter of the actual end it\'s self and of course the total length of the pipe. It\'s the 90 degree one one above the airpump that\'s clearly visible and connects to the BOV/recirculate valve, just to avoid confusion.
I\'m not lazy I just don\'t have a tape measure ;)
I got well confused then - is this the pipe from Turbo to Intercooler you need, or the one from the intake pipe to the bov - which is about 19/20mm id from memory?
B.Martin
It\'s the one that goes from intercooler to bov and turbo, joins the intercooler on the left side of it. The big 90 degree one, does that make sense?
B.Martin
It\'s the one on the right of this pic above the purple coolant hose, just to clarify :)
