Power steering fluid? (fc)
Started by L18M, January 19, 2012, 04:48:54 PM
L18M
i lost my fc haynes manual.
anyone know how much fluid the power steering takes? and whats the best to use? normal atf or other?
thanks
the hat
I just use normal ATF with a tube of stuff from forte that helps seals etc but I also run a massive 12 row oil cooler in the system aoni can\'t advise on how much I require but it will need bleeding and 2 litres should be more than enough
There a level on the dipstick lol
L18M
Quote from: the hat;808119I just use normal ATF with a tube of stuff from forte that helps seals etc but I also run a massive 12 row oil cooler in the system aoni can\'t advise on how much I require but it will need bleeding and 2 litres should be more than enough
12 row oil cooler for the PS?
L18M
Quote from: m1tch;808120There a level on the dipstick lol
your a dipstick :Giggle
be handy to know how much fluid to buy lol
the hat
Yes o had an oil oil cooler lying around so rather than buy a smaller more suited size I just bought sone fittings and used that in the return line too save boiling the fluid which was happening way too much causing the steering too be like driving with cement in the ps lines lol
But since fitting the cooler I\'ve never had an issue
The PS already has a cooler though?
the hat
Not quite man enough tho as if I ended up on full lock too long (remember my racks travel Is maxed out with mazdatrix super lock kit and I have modified steering knuckles)
With the revs up real
High while drifting the fluid would start too overheat and steering would become really heavy
B.Martin
Quote from: the hat;808199Not quite man enough tho as if I ended up on full lock too long (remember my racks travel Is maxed out with mazdatrix super lock kit and I have modified steering knuckles)
This is interesting, post it in the \'drift section\' ;)
the hat
Ha ha I thought the problems of boiling power steering was fairly common
Also at the local crail full circuit days you can stay out as long as you want which can obviously push temps really high too the point I\'m gonna use my spare oil cooler linked too the exsisting one as a preventative just incase
Skifledanabit
the standard PS system takes about 1L of Dex III fluid, so should be the same for other ATF fluids.
[SIGPIC][/SIGPIC]
L18M
Quote from: Skifledanabit;808261the standard PS system takes about 1L of Dex III fluid, so should be the same for other ATF fluids.
thanks man :)
