For Sale - Defi Gauges and FD parts inc 2 Way diff, modified hubs etc
Started by M@r]{, August 26, 2012, 05:57:49 PM
M@r]{
So final bits remaining. Keep checking back as I will add to this list.
2 way diff (not sure of make) £450
Defi Oil Pressure with sender (black face lights up white) £110
Defi Oil Temp with sender (black face lights up white) £110
Defi Tacho with shift light (90mm) £100
Feed Style Front Bumper, bit tatty, needs spraying £80
Another Feed Style Bumper, in white, had work, good for track/drift use. £80
OEM Bumper in white with front lip and indicators. Ok condition £80
Alternator - part polished £50
Coils - not leading £20ea
Plug leads - can;t remember make but decent, recommended by our drag boys. In blue only fitted for a few miles £30
Modified Front Hubs for more lock £170
URAS Tie Rods for more lock £150
Tein Coilovers - work ok, but look ropey. Don\'t think any leaks. £150
Front Discs - Tarox multigrove, hardly any use (because drift car  ) £100
Rear Discs - Grooved/Drilled, can\'t remember make £75
PPF - weld repair, £20
Rear Strut brace, think its Cusco. Very shiney  Â£65
Rear Bumper (OEM) Vinyl wrapped, white underneath £40
Front Undertray £40
20mm Hubcentric Spacers x4 £45 each pair, £80 for all 4
99 Spec front lights - black £80
99 specc front lights - silver £80
Most parts located just outside of Aylesbury. Should be able to get them to NG33 if it helps. No dibs, deposit/cash is the only way to secure. First refusal given to anyone who can collect. Bumpers collection only. Deals for anyone buying multiple parts, particularly if you are collecting. Bank Transfer preferred, paypal accepted if sent as Gift.
rust
the front disc, do they come with pads or just disc on its own ?
lucus walker
hi mark do the uras tie rods come with rod ends ?  what is the benefit compared to std? ones r they thicker & longer & r they new?
R1Dude
Will take uras tie rods if you still have them and will collect regards Ade 07908242931
PaulChater
Hi,
Are the coilovers still for sale. Any pics or way to check there good.
Paul
