Could Lambda / Heat sensor cause VERY loud banging?
Started by Brooktini86, August 26, 2011, 10:43:46 PM
Brooktini86
On my 96 FD I Have just noticed my lambda sensor his now hanging from my exhaust and is scraping along the road. At the same time my exhaust has starting banging very loudly. so loud that i can phyisically feel it going through my drivers seat.
Is this due to the cat sensor falling out or not related?
Also cat heat light has come on the dash... as i would expect.
Performance seems affected... but could be in my head?!
shaunwil
Good chance, its a fair lump of metal. Plus performance may be down because there is a big threaded hole in the exhaust where the sensor was !
Shaun
Brooktini86
Ok its not the lambda, its the heat sensor.
The part where you attach the heat sensor TO has come off. Leaving a nice hole on the bottom of the cat.
Would this cause a noise like a bang/pop?
shaunwil
Could it be gases igniting under the car out of the hole ?
Shaun
Brooktini86
That\'s worrying!
Well I\'ve ordered a new cat now :(
and on the look for a heat sensor.
shaunwil
You sure its not the end of the sensor cable bouncing off the bottom of the car ? Have you had it up on axle stands and looked for possible causes ?
Shaun
Brooktini86
No I haven\'t had the chance yet, I need to get another cat anyway, so I\'ll start from there! Cheers for the help though!
David Nock (RIP)
Don\'t know anything about the FD but in the FB the first sign of a cracked/holed exhaust used to be a savage backfire when lifting off the throttle. That was the original Mazda exhaust did that, with the reactor and air pump system fitted.
Sadly Missed
