Apexi power FC and commander - HELP!
Started by heland, June 21, 2004, 01:53:41 AM
heland
Dear All,
Sorry to be a pain, but as you can see - I\'m a newbieeee, so plese be patient.
My RX-7 was delivered with a Apexi power FC and commander (amongst many other non-standard things that I have\'nt a clue what they are).
The boost setting is set @ 0.9 Bar. Is this the right boost level for the stock turbos?
Regards, Andy
GaryS
Sounds about right to me.  What\'s the Inj Duty reading like ?
maximtaylor
#2
The stock settings for the ecu are:
Setting one: 1st stage 0.8 bar, 2nd stage 0.7 bar
Setting two: 1st stage 0.9 bar, 2nd stage 0.8 bar
A reset ecu uses setting 1.
The actual measure is in kpa, but it\'s virtually identical to bar.
Regards
Max
heland
Gary,
I only got a maximum Injection Duty rate of 85%.
That\'s foot to floor @ 7k rpm.
Does that sound about right?
ScuttleRX
That sounds about right, 85%-90% is good, anything above that will need to start thinking about upgrading injectors/fuel system.
heland
Thanks Guy\'s,
You\'ve put my mind at rest.
