Anyone now an FC vert that\'s breaking for spares?
Started by richrx, August 16, 2011, 04:21:20 AM
richrx
Hi
I think the title says it all... I need a couple of bits asap, and as far as I know there vert specific!! It\'s the clutch slave and master cylinder, I\'m pretty sure the bores have worn. After speaking to specialists I\'ve been told te vert\'s are different. I\'ve previously had Mazda confirm there different part numbers too....
My daily drivers off the road mean time
Richard
If they are different they don\'t need to be - the coupe and vert parts are interchangeable.
Your man from Mazda maybe comparing FD with FC ?
richrx
I had thought that, maaybe I need to double check... Or buy the coupe parts anyway. I am desperate :(
Richard
richrx
Thanks for the advice, got the coupe bits and they fit :) the slave cylinder is different on the coupe, but went on with no issues :) so that\'s the Rex back on the road!!
Richard
