Engine flush?
Started by B.Martin, August 07, 2011, 09:07:47 PM
That\'s the one :):Thumbs-up
Oh - and if you leave the bottom hose on, and have that drain undone, it should fill to the level of the water pump and come out the drain - you\'ll get most of the engine sluiced that way.
B.Martin
Yeah i don\'t want to remove that frickin\' hose ever again in my life... Or at least until i get a new rad!
Im still running the OEM hoses for my radiator, didn\'t touch the rad hoses on the engine lol
B.Martin
Great stuff, if i can get the clearance from the PFO then i\'ll flush the system tonight and then re-fill it with 50:50 coolant/water.
