Anyone got... rac fault code reader?
Started by L18M, August 11, 2011, 11:11:20 PM
L18M
as above, nr somerset area would be nice.
its to fault find my scooby (yes i know im on wrong forum lol) its not boosting :\'(
(yes im not having much luck with cars :()
rx-dave
I\'ve got an OBDII tester and i\'m going to Stroud around 1pm tomorrow (Friday) if that\'s any use? What year is the Scooby? Give me a ring on 07810 098199 in the morning if you want to give it a try, no charge :Thumbs-up.
Dave.
L18M
thanks dave, but bad timing >.<
its a 2002 scooby.
maybe i should be sneeky n buy from argos, use then return it hehe
rx-dave
No probs matey, common problems would be the afm, knock sensor but this shouldn\'t affect boost and the boost solenoid. Does the engine idle ok?
Dave.
I think its cause its infected with pistons
B.Martin
Could have Suba-poo stuck in the Turbo?
wolfie1
i have a delphi bluetooth 1 at my work i can use whenever, its a 2011 machine so bang up to date with all the latest software but it would prob cost you more in fuel to get up here than going to a garage and get it done
L18M
Quote from: rx-dave;781935No probs matey, common problems would be the afm, knock sensor but this shouldn\'t affect boost and the boost solenoid. Does the engine idle ok?
Dave.
the boost solinoind box seems ok and all vac lines. so guess afm or o2 sensor also.
thanks for your help :)
Quote from: wolfie1;782012i have a delphi bluetooth 1 at my work i can use whenever, its a 2011 machine so bang up to date with all the latest software but it would prob cost you more in fuel to get up here than going to a garage and get it done
:chat:driving
