Changing solenoid pack - post 96 FD
Started by rxangus, June 18, 2004, 01:05:14 PM
rxangus
Anybody ever tackled this job? Is it a nightmare? Apparently Pip quotes 3 hrs for it.....
Angus
Smell my Optimax!
jonrx7uk
The Upper Intake manifold is the hardest part.  Once you\'ve had this off a few times it all becomes easier!
Quite a straightforward job if you\'ve got the right tools.
Just be carefull not to break any of the plastic solenoids with the hoses when you lift the UIM off!
Jon
bnaellis
It\'s a straight forward job. you don\'t have to take the uim right off just lift it up out the way. I\'ve done it in about 1 or so but if I was a Garage I would also charge about 3 hours labour.
rxangus
Okay thanks guys....
Just to clarify I am talking about the pack that contains several solenoids which was designed to simplify the rats nest on earlier cars.
How many connections are there on the pack?
Does anyone have a diagram of the solenoid pack connections? All the diags available seem to be for 95 or earlier cars...
Angus
Smell my Optimax!
jonrx7uk
If you do a search on some of the US sites you will come across a few very detailed step by step instructions.
Jon
