what power to expect with hks T51r??
Started by xxl225, July 06, 2011, 11:04:24 PM
xxl225
i\'m just getting my engine ready for mapping and would like to see if anyone could give me an insite in to what kind of power the car will make
its a revolution periferal port engine runnning a hks t51r racing turbo kit
the injectors are
550cc prime
850cc sec
720cc extra rail
thanks
BlitzBoy
You going to run out of fuel quite quickly you need more injector,what pumps are you running? you might squeeze 450rwhp at 1 BAR
You should see well over 500rwhp at 1.3 bar on a PP port with fuelling sorted, at 1.8 BAR you should see 570rwhp
Rotorstock winner 08,09
New Project
"el fénix" RX2 by Mark & Mark
xxl225
Twin bosch 044
What injectors should I run?
12at
I would think 2 1000s 2 1700s and 2 1700s and 2 ID2000s as the secondaries would give you more than enough..
xxl225
can you even get 1000cc side feeds for primaries and what make are 1700cc side feeds?
12at
BlitzBoy
If you want to keep side feed, do what Ross did in his drag car, 2x850cc primaries,2x850cc Secondaries, then he had another secondary rail welded to the UIM with another 2x850cc, and then 2 x 850cc mounted in the Elbow.
My advice to make it simple like what I have done, get top feed rails for the Primaries and Secondaries and run 4x1680 Bosch injectors like I do, enough injector for 550rwhp-580rwhp
New Project
fil_auto
this sounds like an interesting car / setup... pics please :)
keep us posted Sir ....
xxl225
ok but what about using 1680 side feeds and 1000cc top feeds to replace the 850cc and 720cc
