How to tell if its a Turbo II
Started by yellowmazdaman, July 12, 2004, 09:30:04 PM
yellowmazdaman
I have found an engine in the junkyard by my house.But the owner doesn\'t remember what year of car it came from so I don\'t know if its a 13b Turbo 185hp or a 13b Turbo II 200hp.Can someone hepl me out?
deevious
The turbo is different, if it\'s still on. I\'d have to look up the specifics though as I don\'t know these by hart.
Also the intercooler on the 200bhp version is slightly larger, but you have to see the two side by side to see the difference.
there\'s actually quite a few differences in the ancilliaries. Easiest is to check a website that has all the technical data
88GT-R
Hi
 If the engine is on it´s own, look at the elbow above the water pump. If it has a cap, it is an S4. If it is a solid black or silver elbow, it is an S5. Look at the air flow meter. Big and chunky=S4. Smaller and round/oval = S5.
Hope this helps. There is another thread with all of the differences. Do a search.
John
88 GT-R
RexRyder
QuoteOriginally posted by yellowmazdaman
Actually both engines are Turbo II.
hIGGI
S4 13BT has knock sensor on center iron
S5 13BT has knock sensor on rotor housing
