Practical to swap out the subframe with engine in place?
Started by Aubec, June 16, 2011, 09:30:15 PM
Aubec
Hi chaps, my front subframe looks a little crusty - just wondering if its practical to change it without pulling the engine?
Was thinking if I could jack at the gearbox  as if I was swapping engine mounts then I could just unbolt it, drop it and reinstall a nice, low mileage and newly powdercoated one?  Only thing is not sure where I\'d put axle stands if the subframe was out...
Aubec
1995 UK Silver FD
antnicuk
thats how i would do it,  you could put the axle stands at the jacking points on the chassis,  if you are worried about damaging the chassis you can spread the weight with a piece of wood up agains the seam.
you will probably need to have your alignment done again
Aubec
I\'m going to be installing newly polybushed arms all round anyway, so would probably do it all at once, and then only have to pay for alignment once too!
BUT one project at a time, need to get my turbo installation finished!
Aubec
1995 UK Silver FD
batman
i did this to mine about a month ago just used a 2 poster and had a transmission jack in the middle supporting the sump
