vertical maf?
Started by L18M, June 16, 2011, 05:13:32 PM
L18M
will a maf sensor work if its positioned vertically?
just wondering what will happen if its vertical and you go over pot holes, will the engine run rough due to the valve in the maf being knocked about?
thanks thanks.
I know that you can see the values change on logging when you go over a bump, its a sprung cone which isn\'t as bad as a flapper AFM, why don\'t you look at fitting a hotwire MAF?
Lil-Steve
I know you can mount Karmen-Votex style AFM\'s however the hell you please not sure about the rest though....
Lil-Steve is.... loving it when a plan comes together.
I think you might be able to, although im not sure why you would want to mount it like that, I wouldn\'t really want to mount them different to OEM orientation though
