Spraying plastics/fiberglass?
Started by RobMatthews, June 26, 2011, 03:30:15 PM
RobMatthews
I am about to give my track car a lick of paint,(using cellulose).
Question is can i do the bumpers in the same way as the metal work or do i need to put some sort of aditive in to stop the primer/paint cracking on a more flexable surface such as the plastic bumpers/fiberglass bonnet?
thanks rob
parts supplied by;
DM-Motorsport.co.uk
Info@DM-Motorsport.co.uk
shaunwil
There is a plastic primer and a plasticiser that is added to the paint. A friend did an old car years ago and added some stuff in the mix to get it to flex.
Shaun
Grant Monkhouse
I would do a tester action to see what happens. Have to make surethe surface is clean before any painting.
2pac paint is much better than cellulose. Easier to rub down afterwards and gives a much better shine.
RobMatthews
Thanks plasticiser is what i\'ve heard bonce around befor, i\'ll go down to the paint shop tomorrow see if i can sound like i know what im on about ...
Thanks grant but i haven\'t got the equipment to use 2 pac! ie no air fed mask! or propper spray booth :-(
parts supplied by;
DM-Motorsport.co.uk
