Braking power suddenly disappears
Started by peasjam, June 14, 2011, 04:02:44 PM
peasjam
The brakes on my FD seem to have developed an intermittent issue where I loose 80-90% of my braking power.
Brakes feel absolutely fine most of the time and the peddle feels normal. Sometimes however it\'s as if my brakes are barely there and the feel of the peddle changes slightly. This can \'come on\' while brakes are already applied.
Any ideas what this can be? It\'s just been MOT\'d so pads and discs are fine, it\'s intermittent anyway which I think suggests a problem elsewhere.
Thank you,
Matt.
Aubec
Fluid could be waterlogged, get it changed.
Aubec
1995 UK Silver FD
shaunwil
Check the One way valve in the vacuum line too between the UIM and the brake master. Could be a knackered vac assist !
Shaun
Perhaps check the bottom of the brake booster, perhaps its got a rust hole meaning it isn\'t assisting the brakes?
carlbrainiac
Is it only when braking hard? Could just be the ABS kicking in. Thats one thing that annoys me with my Subaru. Stupid ABS cuts in WAYYYY too early. Drives me nuts. Almost tempted to pull the fuse lol. Havent had the ABS cut in on the rex yet.
peasjam
Cool, I\'ll check the things suggested. It\'s definitely not ABS, never had it before.
SiH
Quote from: shaunwil;769019Check the One way valve in the vacuum line too between the UIM and the brake master. Could be a knackered vac assist !
Shaun
My money\'s on this :) The pipe isn\'t that expensive.
Indian
it sounds like your Master Cylinder might be going. You want to check your ABS motor too. bridge the relay and see if it turns on
