rotary compression tester in SW?
Started by L18M, May 28, 2011, 06:31:55 PM
L18M
anyone know anybody with a rotary compression tester in SW (somerset area)?
Just want to get a test done as when warm it takes a little longer to start.
Water temps are fine (constant 82 deg C), oil press is fine (on stock gauge) and not burning lots.
cheers
captainbizzaro
What ECU are you running? When you say longer - how much longer? Just wondering as a comparison to mine. Mine starts better from hot than cold though as my cold crank map is quite rich.
davehg
keith on here has one, he is in the trader section
davehg
he is down mine possibly tomorrow so could get him to bring his tester and meet there if you contact him
L18M
L18M
Quote from: captainbizzaro;765346What ECU are you running? When you say longer - how much longer? Just wondering as a comparison to mine. Mine starts better from hot than cold though as my cold crank map is quite rich.
AP engineering pfc
on cold it runs after 2nd or 3rd crank.
when warm it usually runs after 5th or 6th crank but seems to struggle a bit.
