Radio fitting
Started by Ceri, May 13, 2011, 09:48:22 AM
Ceri
Hi All
I have just bought a 1999 RS and want to fit a double din JVC into the hole in the dash.  There are 2 white multi-plugs viable and a flat grayish conector on a stiffer wire covered in foam, but no visable aerial jack.  Is there a straight forward way of connecting this lot into the back of the new JVC?  My local Auto electrician says that there must be an amp somewhere in the car but he does not know where so will have to bypass the current wiring by running all new wires to the speakers etc.  Is this right?  Is there anyone who does this job in the South Wales/Cardiff area without having to rewire the system while charging by the hour?
Ceri
batman
it sounds like it has a bose system in it bud im in swindon not far i am a car audio engineer and could do it for you but depends on if you want to travel
Ceri
Thanks Batman (can\'t believe I just said that)  Will you be able to wire it via the amp (existing wiring)?  If so how much would you charge/how long will it take to do?
Ceri
batman
depends if theres a diargram available then yes just a case of lowering the out put so the standard amp doesnt try to amp 4 x 50 w then pop no speakers . price does depend on the job but i try to help not make profit if ya get what i mean
Ceri
Cheers, I\'m on hols next week so may contact you on my return.  Thanks again for replying
Ceri
Hi Batman
I took the car to Extreme Sports and Performace nr Bargoed South Wales who sell 7\'s due to another issue and Dave there fitted a mazda part, 2 into 1 conector and fitted the unit.  The 2 white plugs were for front and rear speakers respectively.
Thanks again though
Ceri
