Need to convert KPH - MPH
Started by free45, May 11, 2011, 05:26:10 PM
free45
what is a good converter to go for and where because i search on ebay and all they say is for an electronic digital dashboard so i need some help please.
Competition PZ
One of these fit ? http://www.kmh-mph.co.uk/mechanical-speedo-conversions.asp
Or a new dial back ??
What\'s wrong with the old-school stickers on the dash at the important points :) :)
free45
I\'ve seen those ebay ones but it says electronic speedo, so im assuming this means ur speedo is digital, mine is electronic odometer but clocks for dials
rx-dave
The ebay one\'s are fine and just what you\'ll need, you\'ll need to remove the clocks and wire in behind. It\'s not a difficult job to do and shouldn\'t take you more than an hour tops for the first time \'experience\'.
Dave.
free45
Cheers dave, once i have wired it in ill then need to grab myself a MPH dial, I take it with this kit from ebay will also take the limiter off? anyone have any experience with these kits?
James
tiger18
Ive installed one of them ebay ones theres only a few wires to put in behind the speedo. It removes the speed limiter. You dont have to do anything with the clocks its a convertor so now when your driving and your speedo says 30kmh you are doing 30mph ect ect understand?
rx-dave
James, Mr Tiger is correct and the converter \'chip\' is all you\'ll need. Just put a tiny square of black tape or a drop of black paint over the k on the km/h print on the speedo face so it\'ll read m/h instead :Thumbs-up.  If you get problems taking the pod out give me a ring on 07810 098199 and i\'ll try to help!
Dave.
free45
Cheers for all ur replies has been very helpful, will try and order one in
