passenger door not locking
Started by davehg, June 13, 2004, 10:41:28 PM
davehg
can anyone help? is this common? it wont lock with the key only if you press the handle down inside the car but even then t takes a lot of force....
is there a common fault with them?
thanks
dave
davehg
J4P RX
Id probably try locking it with the key and then seeing if the button works.  If not, take of the handle and see if theres anything bad looking in there!
Lee
davehg
it only locks with the key if you keep yurning it a few times :(
J4P RX
Its only 2 bolts to get the handle off - I recon your best bet is to look inside and maybe something is loose.
Sounds like the rod has jumped of the lock.
Pull the plastic cover off the inside of the door then undo the three 10mm [spanner size] nuts holding the lock to the door and hopefully you will see that the rod just needs popping back in.
Hope this helps.
davehg
super thanks guys ill take a look this afternoon. ill keep you posted.
