A sad sad day
Started by John RX7, May 07, 2011, 02:00:23 PM
dudsey
If you had a crack in the housing/water jacket you would probably have an overheating issue. As said if there is water in the chambers then its probably seal failure.
John RX7
yeah ive been topping it up for a while,since i brought the car really the level sensor always going off so just going to get it rebuilt and ported,start fresh
John RX7
Can anybody tell me how bad fuel consumption is on a bridge port will i need to upgrade fuel system to match power
turbotoaster
depends how aggressive the bridge is, also whether its a half or full bridge.
and then it goes down to who maps it as that will potentially help fuel consumption by being leaner in the vacuum areas of the map.
but typically yes a bridgeport will use more fuel than a stock/street port
