speed de-limiter
Started by brundish24, September 02, 2010, 10:47:05 AM
brundish24
is there any way to get rid of the top speed limiter and keep to speedo reading out in kmh / does the apexi pfc do this or not?
trotter
see here...
http://www.rx7club.com/showthread.php?t=668599&highlight=speed+%2Blimiter
if you have a PFC it will delimit anyway, but the speedo will peg at 112mph, you will need to use a hand commander (im selling one!! ;)) to view speed from that. Although there is a mod you can do to the speedo cluster to fix it.
hth
graeme
Work hard, play hard house :D
marcusd666
I have one of these fitted to mine works fine even makes the PFC read in MPH as well the speedo. Its only four wires I think and had it fitted down by the ECU not behind the dash.
Click me
marcus
'92' RX-7 FD3s type-R Black
'04' RX-8 231 Winning Blue (sadly missed)
'10' AUDI A5 S Line Convertible (Daily Drive)
brundish24
cool ive got a pfc and a commander i was goting to buy some plasma dials they have both mph and kmh on its face and goes up to 180mph.
ChrisS
Quote from: marcusd666;714474I have one of these fitted to mine works fine even makes the PFC read in MPH as well the speedo. Its only four wires I think and had it fitted down by the ECU not behind the dash.
Click me
Which wire is the one for the speed signal?? I have a convertor and the dash is out so was going to fit it behind the gauges but cant seem to find which is the correct speed signal wire to cut into.
brazley
I would also like a bit of help on this - got a MPH converter chip from ebay but unsure which wire is the "signal" wire I need to cut into. Any help appreciated!
