Ordering Gearbox Parts - MazdaTrix Equivalent?
Started by Lacey, April 28, 2011, 03:39:00 AM
Lacey
Looking for an equivalent to MazdaTrix as they only really like shipping within the US without a creepy amount of personal information.
This is what I need to do;
http://www.mazdatrix.com/faq/shiftbsh.htm
So, I need to order the following....
(the following codes are used on MazdaTrix, I don\'t know if they\'re MazdaTrix\' own codes, or the actual product code, so I thought I\'d include them anyway.
79-95 (Upper)            17-481A-M508 (upper gear stick bushing)
84-95 (Lower)            17-4810-M501 (lower gear stick bushing)
I also need to order......
81-95 Inner Boot on shift lever
(Bolts to trans tower)
Comes              with new gasket            17-480A-M513
Along with (if it\'s not included)
Gasket for above boot            17-4740-0303
And if I can find them, the 3-piece set of outer boots.
86-92 Middle Boot Kit
(3              pieces, bolts to chassis trans tunnel)            64-490B-FB01
Any UK suppliers that aren\'t charging some idiotic price would be very much appreciated, all of the above (minus the 3-piece boots) comes to about $50, with the 3-piece boots it comes to $100, I\'m looking for it for about the same price from the UK new, or a fair bit cheaper in used but working order.
I need this stuff before I can actually drive the car, as it is the gearstick moves about far too much for me to feel I can safely select a gear without missing or going into the wrong gear, so this is stuff I actually need to get the FC back on the road. :/
Any help much appreciated, or if anybody has this stuff lying around I would be very grateful, and compensate. :)
Posted this in Technical rather than Wanted as I\'m more interested in ordering new parts but don\'t know where from, but am happy to consider spare / used parts depending on quality :)
SuperCripple!â,,¢ & Co-Owner of JapGirls.
Happy owner of a constant work-in-progress, Red-Interior[COL
Will66
Try Mazda Rotary Parts, they may be able to get hold of them for you.
"Eat it with a chopstick!"
Even Mazda - and those may well be the Mazda part numbers - have to check the fiche later...:Typing
Lacey
