what temp do fans come on?
Started by merlin2002, April 29, 2011, 06:55:50 PM
merlin2002
Hi guys
Just a quick question?
What temp do the fans come on? on a fd3  as mine dont come on at idle that ive noticed, just worried about cooking my engine now ive fitted a new radiator?
thanks
Rob
cyman
if you mean from water temp fd thermo switch is 107 degrees then there is seperate temp set at ecu then your a/c switch. the fans are 3 speed and increase with each of the previous settings.   so a/c switch speed 1 then if thermo switch comes on they go to speed 2 and so on.
an easy mod that ive done is fit an fc thermo switch which is a straight swap and is 89 or 87 degrees so comes on a little earlier.
hope this makes sense
gsb876
i think mine used to come on at 95oC, however i think you can reset them to come on at whatever temp you feel is important.
