longer wheel studs
Started by matto, April 12, 2011, 02:56:59 PM
matto
anyone know where i can get some wheel studs for the rear 10mm longer?
dthebuk
is this for slip on spacers?
have you looked into bolt on spacers?
:burnout
matto
no i have 330 mm rear brake conversion and the bell is quite thick for caliper clearance
bimbleuk
I\'m fairly certain the studs are common M12 x 1.5 so any place that sells nuts and studs etc.
I\'ve bought longer ones from Merlin Motorsport myself for a kit car in the past.
kev-yorks
Clive MRP (top of the page) will be able to supply them no problem.
Regards Kevin
SiH
Bear in mind replacing rear studs is am absolute pig. You\'ll need a new rear bearing IIRC as you have to split it.
