Water leak
Started by oliverash, March 04, 2011, 10:21:54 PM
oliverash
Leave the car for a week and something has either broken itself or stopped working.
I now have a water leak. As i top up the water it drips straight out from just below/behind the pulley. What is the cover directly behind the pulley and are replacement gaskets available from somewhere?
thanks
TRIND-FD
Sounds like your water pump is knackered, Mazda rotary parts on here will sort you out a new one.
Keith
V8 fd\'s rock :cool
davehg
as keith said.. youll need a new pump and gasket... give clive at MRP a call.
oliverash
Cheers guys im on the case
