electricle info needed z32 of manual
Started by imiitek, April 06, 2014, 03:27:42 PM
imiitek
#15
right got it going on motec the 4d was the 0v but also come across another problem the negitive side of the crank sensors were also in the stock ecu
so used pin 27 on motec 0v and conected both 4d and crank sensor( - side)
but still had starting isues due to ether crank sensor wire in engine bay or the sensor its self had issues had to keep moving loom to get signal
ether way its running bit crap but running
this is the errors i was talking about
tomaro i will rip the loom out and put fresh wire in and take off the extra stuff not used
thanks for your help so far :)
will be back with more findings or problems lol
boosted
Cool glad you got it sorted ! I looked at the rx8 wiring which is very very similiar and the equivalent wire is 4U and is Mazda kindly marked it ground at the PCM! Ive ran seperate earths and linked them all after my rewire just to be sure. Keep me posted as im going piggy back next year so all good info.
imiitek
#17
got loom out and taged the used stuff
pritty much all the conectors are broken or the wires are all got cracks exposing wire
so will need to order new set of plugs
only tps, iat, 4x injrctor, 2x water, iacv, air temp, and 2xcrank conectors
i no tripoint sell the but does any 1 no of a local suplier
