Car too loud and too low!
Started by ANRX7, February 13, 2011, 05:42:16 PM
bigdawg
Quote from: SiH;743362I certainly wouldn\'t use an ECV on track - it\'s not really what they\'re meant for. You need proper silencing - so a new backbox/extra silencer etc.
If you\'re bottoming out it would suggest to me that you either need to try knocking up the compression damping on the shocks, or increasing spring rates.
Paddock is never going to be kind on suspension!
Im in the exact same situation - same suspension and problems. (not trying to hijack the thread)
can anyone suggest anything or point me in the right direction?
i have ZERO knowledge about suspensions.. i dont know if mine has even failed or anything :/
ANRX7
Thanks Laeeq, will go with your advice since you know the car.
